[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4757: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4759: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4760: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4761: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
NEW D-MAX /MUX /COLORADO FORUM •
It is currently Wed Aug 12, 2020 9:33 am
Post new topic Reply to topic  [ 158 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15, 16  Next
 Post subject: Re: ARB suspension
PostPosted: Tue Apr 07, 2015 7:09 pm
PostPosted: Tue Apr 07, 2015 7:29 pm
As Danno says , too many hassles and I have had plenty . The spring works will set the vehicle up if there is any problems they will change the springs , no telling me to load 600kg on the tray .
I don't know when the springs will be fitted , the 4wd shop has all my stuff ready to go , he needs to find 3 days to fit the Bar,Winch , Snorkel , E-lockers and Sliders , I said no hurry .
Will get the springs after that ,
PostPosted: Tue Apr 07, 2015 7:35 pm
PostPosted: Tue Apr 07, 2015 9:51 pm
The legalities of ESC and a suspension lift are apparently being discussed between all state and territories atm, with a possibility of relaxing the rules because as it stands if you read the rules correctly you can't legally lift a vehicle without proving that the ESC is not affected, thankfully it's pretty much ignored by everyone, insurance co. included.
PostPosted: Wed Apr 08, 2015 3:13 pm
PostPosted: Wed Apr 08, 2015 5:47 pm
PostPosted: Wed Apr 08, 2015 6:02 pm
For modification codes contained in this Section of VSB 14, evidence >>>>>>>>> should <<<<<<<<<<<< be obtained either
from the vehicle manufacturer or through testing to determine the impact on the ESC system
https://www.infrastructure.gov.au/roads ... 1%20v3.pdf
2.6 MODIFICATIONS TO VEHICLES EQUIPPED WITH ESC
Many modern vehicles are now being equipped with a safety feature known as Electronic
Stability Control (ESC). (ESC is also known by other terms including Vehicle Stability Control or
Dynamic Stability Control).
ESC provides motorists additional safety in terms of vehicle stability and handling, particularly in
difficult situations where loss of control could otherwise occur. ESC uses computer technology
to assist the driver in maintaining control in emergency situations – particularly when executing
avoidance manoeuvres involving sudden swerving and in cases when the vehicle begins to
slide and rotate sideways.
Braking is automatically applied to individual wheels, such as the outer front wheel to counter
oversteer, or the inner rear wheel to counter understeer. Some ESC systems also reduce
engine power until steering control is regained.
ESC is programmed by the vehicle manufacturer for the vehicle to which it is fitted taking into
account a number of design parameters such as brake, engine and transmission performance,
tyre specifications, steering systems, suspension (type and performance characteristics), mass
of the vehicle and weight distribution.
For modification codes contained in this Section of VSB 14, evidence should be obtained either
from the vehicle manufacturer or through testing to determine the impact on the ESC system.
To remain within the scope of this Section of VSB 14, a vehicle fitted with ESC must not be
modified if the operation of the ESC is affected unless the ESC system is adjusted accordingly.
Persons wishing to modify vehicles equipped with ESC must contact their Registration
Authority for further information and guidance
PostPosted: Wed Apr 29, 2015 4:23 pm
I have now had a MCC Single Hoop winch bar and Runva winch with synthetic rope fitted to my Dmax for only 2 days I have done about 400k , the front is now 10mm lower than std hight .
PostPosted: Wed May 06, 2015 2:01 am
I got a phone call from the shop that did my GVM upgrade a rep from ARB wants to have a look at my front suspension this Thursday, it will be very interesting to see what she , yes she has to say .
PostPosted: Wed May 06, 2015 11:12 am
Like I said above I'm getting my Suspension looked at tomorrow at the shop that did the work .
I have a couple of things I need to mention , the bloke that fitted the lockers asked me who had the wheels off last because they had stuffed a wheel stud and just belted it on , he replaced it for me.
Now I notice the front tyres scrubbing on the inside , I very much doubt it had a wheel alignment.
How hard is it to get good work done now days .
