[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4757: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4759: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4760: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4761: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
NEW D-MAX /MUX /COLORADO FORUM •
It is currently Wed Aug 12, 2020 9:46 am
Post new topic Reply to topic  [ 158 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16  Next
 Post subject: Re: Cv axles
PostPosted: Thu May 07, 2015 12:42 pm
Hey Jacko if you don't mind getting ARB to change coils I got the hilux ones and my ute is sitting where I expected. I have bar winch and steps/bars. If your experience means you want to tell them to place it somewhere else no one can blame you so it has dragged on a bit.
Sent from my ZTE T83 using Tapatalk
PostPosted: Fri May 08, 2015 6:52 am
PostPosted: Fri May 08, 2015 7:10 am
Mate, that is great news. Damn pity it took so long.
PostPosted: Fri May 08, 2015 7:16 am
There was a choice of two springs I took the bigger or stronger of the 2.
PostPosted: Fri May 08, 2015 8:16 am
 Post subject: Re: ARB suspension
PostPosted: Mon May 11, 2015 7:50 am
A tip if you are going to use the Old Man Emu add a leaf. I did this to change my 0 to 300kg springs to 300kg constants
If you purchase the 300kg constant as a spring pack the anti friction pads are fitted as standard. if you use the add a leaf system it does not come with anti friction pads as standard and yep you guessed it the damn thing is noisy as
So back next week to have the spring pack pulled apart for the pads to be added
A tip for all the players
I come from a land of Bintang Singlets HSV's and 50 dollar Lobster known as Perth
PostPosted: Fri May 29, 2015 4:53 pm
Well after so long ARB are fitting 2 extra leaves to the rear each side so will give the extra lift and cope with long range tank etc especially over time, I will re measure once fitted. Oh yes and free of charge which is bonus....
PostPosted: Wed Jun 10, 2015 8:20 am
Well my Dmax is in the ARB shop today to have the suspension sorted , with any luck it will come out sitting 30/35mm higher than std instead of 10mm lower , I really hope it's all good , it's only taken 4 months
PostPosted: Wed Jun 10, 2015 4:02 pm
I will have to remeasure my front end now that the new coils have been in for a little while now.
PostPosted: Thu Jun 11, 2015 4:26 pm
I have just driven home from getting the new springs fitted to my Dmax , HD Prado springs so I was told .
The drive home is about 70k , I measured it as soon as I parked on the concrete
going on the shops numbers it has dropped 6mm sides in the 70Ks
The front right is now only 9mm higher than std
The front left is 16mm higher than std .
I know the 35mm lift is approximate ( give or take a couple ) but it's still not even close
The rep from ARB Head Office did ring me as I pulled into my drive to see what I thought , I hadn't measured it at that stage , she wants me to keep her informed , I appreciate that and I will
But really this has taken weeks , I have just about had enough
What would you Blokes do .
