It is currently Sun Apr 05, 2020 5:23 am
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: 2 inch tough dog
PostPosted: Wed May 17, 2017 5:40 am
So you've only just contacted TD now and they sent you new leaf packs straight away?
PostPosted: Fri May 19, 2017 6:26 am
No contacted them from the very start.
They didn't give a rats. Basically said to bad tell someone who cares.
PostPosted: Fri May 19, 2017 6:28 am
They knew there was a problem hence the change in the spring pack now.
PostPosted: Fri May 19, 2017 7:37 am
Did they say what has be changed?
PostPosted: Sat May 20, 2017 3:06 pm
All they done was get fixed Teflon pads on the first leaf pack
PostPosted: Mon May 29, 2017 5:04 pm
So the brand new suspension went in today.
The mk2 version is actually way worse!!! I dunno what the hell it is.
Atleast the first lot took a few thousand kms to get clunky
These ones are worse straight off the bat!!
I put a rubber bump stop under the first leaf pack on the other ones and tht seemed to dull it down. Guess I'll do same with these
PostPosted: Mon May 29, 2017 8:55 pm
I dunno gmax do you still have the original std springs , I would be taking both sets of TD springs back tell em to shove em , see if you can get a refund , then go,and see Ray at Morwell Springs he will sort it out .
PostPosted: Tue May 30, 2017 7:54 am
Yeh the shop I got them from basically couldn't give a rats
Might try the old go pro under there to sus it out.
Because if it isn't these Springs only thing I can think of is rear wheel bearings but they seem fine.
Tub mounts are tight body mounts tight exhaust fine spare wheel fine.
PostPosted: Tue May 30, 2017 9:56 am
PM sent.
PostPosted: Tue May 30, 2017 10:49 am
Jacko I've rang spring works goin to have a chat with him aswell
Thanks danno
