http://newd-max.net/
2 inch tough dog
http://newd-max.net/viewtopic.php?f=11&t=2350
Page 3 of 6
Author:  Danno [ Wed May 17, 2017 5:40 am ]
Post subject:  Re: 2 inch tough dog
So you've only just contacted TD now and they sent you new leaf packs straight away?
Author:  gmax [ Fri May 19, 2017 6:26 am ]
No contacted them from the very start.
They didn't give a rats. Basically said to bad tell someone who cares.
Author:  gmax [ Fri May 19, 2017 6:28 am ]
They knew there was a problem hence the change in the spring pack now.
Author:  Jackofjr [ Fri May 19, 2017 7:37 am ]
Did they say what has be changed?
Author:  gmax [ Sat May 20, 2017 3:06 pm ]
All they done was get fixed Teflon pads on the first leaf pack
Author:  gmax [ Mon May 29, 2017 5:04 pm ]
So the brand new suspension went in today.
The mk2 version is actually way worse!!! I dunno what the hell it is.
Atleast the first lot took a few thousand kms to get clunky
These ones are worse straight off the bat!!
I put a rubber bump stop under the first leaf pack on the other ones and tht seemed to dull it down. Guess I'll do same with these
Author:  Jackofjr [ Mon May 29, 2017 8:55 pm ]
I dunno gmax do you still have the original std springs , I would be taking both sets of TD springs back tell em to shove em , see if you can get a refund , then go,and see Ray at Morwell Springs he will sort it out .
Author:  gmax [ Tue May 30, 2017 7:54 am ]
Yeh the shop I got them from basically couldn't give a rats
Might try the old go pro under there to sus it out.
Because if it isn't these Springs only thing I can think of is rear wheel bearings but they seem fine.
Tub mounts are tight body mounts tight exhaust fine spare wheel fine.
Author:  Danno [ Tue May 30, 2017 9:56 am ]
PM sent.
Author:  gmax [ Tue May 30, 2017 10:49 am ]
Jacko I've rang spring works goin to have a chat with him aswell
Thanks danno
Page 3 of 6 All times are UTC + 8 hours
https://www.phpbb.com/
