http://newd-max.net/
GVM upgrade suppliers in Perth WA
http://newd-max.net/viewtopic.php?f=11&t=2608
Page 1 of 1
Author:  rwally [ Mon Sep 25, 2017 5:57 pm ]
Post subject:  GVM upgrade suppliers in Perth WA
I'm considering a GVM upgrade for our Dmax auto 2013 LSM crew cab.
After seeing the threads here I have a couple of questions:
(1) What is included in a GVM upgrade (ie: shock absorbers, springs ?, etc ) ?
(2) Any recommendations or suggestions as to who could do this in Perth WA ?
Author:  Jackofjr [ Mon Sep 25, 2017 6:48 pm ]
Post subject:  Re: GVM upgrade suppliers in Perth WA
I got a ARB GVM upgrade for my Ute , it's just Springs and Shocks front and rear , greasable rear shackles , it give me a extra 270kg . GVM is now 3220 . ARB was the only one available when I bought my Dmax
Lovells now do a GVM upgrade , I would go with them now .
A GVM upgrade is a good idea , most of us change the suspension anyway , might as well pay a little extra and get the mod plate , you can then overload and break ya Ute in half legally .
Author:  93MU [ Thu Nov 02, 2017 12:32 pm ]
I rang up Lovells in Melbourne last week and for their 3600 Kg AGM upgrade they wanted $4800, don't think so. :D :)
Author:  Bob [ Thu Nov 02, 2017 2:52 pm ]
I had mine upgraded as part of my purchase through Major Motors back in 2014. They used ARB out at Canning Vale at a cost of $2,186.54. Because it was a new vehicle it was a straight forward job as all the engineering was based on a stock, off the production line vehicle.
I would expect that it will cost you a bit more than this as your vehicle is now a few years old and any accessories you have added change the engineering so basically you need to have the engineering done specifically for you vehicle.
This is a description of the parts they had on the original quote -
COIL DMAX/COLORADO 2012 ON
SPORT STRUT DMAX/COLORADO F 2012
ON
SPRING DMAX/COLORADO 2012ON 600KG
SPORT SHOCK NAVARA D40 -ROME
U BOLT WASHER & NUT
GREASABLE SHACKLE HILUX 2005 ON
SPRING BUSH KIT HILUX 2005 ON
FITTING
WHEEL ALIGNMENT CHECK
OME DMAX ADR COMPLIANCE KIT
Hope this helps. :D
Author:  Duck [ Fri Nov 03, 2017 4:40 pm ]
There is no difference in what needs to be used for GVM upgrade it will be on the appropriate companies approved suspension list. The big difference is when we do a new vehicle it is australia wide blue plate on a used vehicle the blue plate is state specific. So potentially across a state line and tour GVM is not current. Any of the majors offer it. ARB/TJM/LOVELLS ec etc most will have there own staff qualified to blue plate it. They just wack on the plate no difference to any other sus job. Do you need the GVM as have found a lot of people get it just incase, if you dont need it just get the sus you want and save the costs of plate & papertrail needed. Getting new sus myself this weekend. OME. Let us know how you get on.
Author:  Bob [ Fri Nov 03, 2017 4:58 pm ]
Agree Ducks but I still believe that the engineering needs to take into account any additional accessories you have added. As mentioned, my upgrade was done before any other items were fitted so the sums are done on a standard vehicle therefore the cost is shared over and over again compared to a one of for a second hand car.
I also agree that if you don't need it then don't get it done, go the cheaper option of just upgrading the suspension. In my case I had done the sums and I was 20kg over the allowable payload so to keep it legal I had no choice.
It is also nice to know that I can through more gear in the tub if I really need it.
Author:  Danno [ Fri Nov 03, 2017 8:23 pm ]
Duck wrote:
The big difference is when we do a new vehicle it is Australia wide blue plate on a used vehicle the blue plate is state specific. So potentially across a state line and your GVM is not current.
Your GVM upgrade will stay current anywhere in Australia as long as it's still registered in the state that issued the plate, in our case we changed states and lost the upgrade but at that point I couldn't have cared less anyway, it had served it's purpose.
Author:  ch2 [ Fri Nov 03, 2017 10:55 pm ]
I'd be pretty certain that ARB and Lovell's don't do any specific engineering for an individual vehicle, regardless of what accessories you have. They have already done the work for GVM upgrades on the make and model to get ADR compliance already. See:
http://rvcs-prodweb.dot.gov.au/perl/479 ... 143046.cmd
and
http://rvcs-prodweb.dot.gov.au/perl/448 ... 083053.cmd
A GVM upgrade is just bigger springs and shocks, a compliance plate and a couple of stickers. No 'special' engineering. If you look at the specs in those documents the ride height has also increased by 50 mm. Most 2" lifts have the same weight carrying capacity. Lovell's upgrade is nearly 300 kg more than ARB's! I wonder what the ride height is at that load? I wouldn't be surprised if ARB will sell you the exact same suspension without the plate and stickers as a lift. As Jackofjr says, a GVM upgrade is about the plate to make it all legal.
Lovell's has a good list of the inclusions on their website - https://www.lovellsauto.com.au/product12j.php
Bob wrote:
I had done the sums and I was 20kg over the allowable payload.
Calculated or weighed? Before or after lunch? Seriously, a tank of fuel is about 60 kg. Do you carry water?
Author:  Danno [ Sat Nov 04, 2017 5:01 am ]
After all the barwork, canopy, tank, roof racks etc. were fitted to my vehicle which was nothing over the top and what you would expect to fit to a vehicle travelling around Oz and WITHOUT any of our camping gear, clothes, food etc. the car was weighed and it was 2900kg...50 kg under GVM and with only me in it!. A GVM upgrade is a worthwile investment.
Author:  Bob [ Sat Nov 04, 2017 6:34 am ]
These calculations were done before I had even signed for the new car so a bit hard to weigh it. :D
Also as I was fitting a long range tank it was a wee bit more than 60kg. :?
Page 1 of 1 All times are UTC + 8 hours
https://www.phpbb.com/
