It is currently Wed Aug 12, 2020 8:08 am
 Post subject: Ironman Add a Leaf
PostPosted: Tue Feb 18, 2020 1:30 pm
Has anyone fitted an Ironman, Add a Leaf to their D-max. I have a 2019 LST with canopy, draws and fridge slide and the top spring has flattened to near straight. So appears to have dropped around 40mm. I am not looking for a 'lift' or gvm upgrade, just back to where it started.
Brian
 Post subject: Re: Ironman Add a Leaf
PostPosted: Wed Feb 19, 2020 1:08 pm
Brian
Try going to a 4wd suspension place who upgrades Dmax susp. They throw out near new spring packs when people fit a full raised set after purchase of their vehicle. The LST traditionally has softer suspension than LS or tray models and so those packs will be stronger and up lifting. If you can get a set of the heavier springs (usually thicker leaves) it is a simple replacement task to fit both packs. It may cost very little. Adding a leaf from Ironman is doing the same and overall a heavier spring pack as well.
PostPosted: Wed Feb 19, 2020 5:30 pm
Thanks mydmax :D
PostPosted: Thu Feb 20, 2020 7:49 am
Hi Brian
If you are anywhere near the sunshine coast i have a full set front and rear springs and shocks off my 2016 lsu twin cab with less than 20k
you are welcome to have free.
PostPosted: Thu Feb 20, 2020 12:28 pm
Thnx for the offer towtug, but I couldn't be much further away. I'm in Melbourne :o :o
PostPosted: Sun Feb 23, 2020 8:04 am
Will also need to look at the shock to control the extra spring rate I would think.
