[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4757: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4759: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4760: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4761: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
NEW D-MAX /MUX /COLORADO FORUM •
It is currently Wed Aug 12, 2020 9:42 am
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3, 4, 5  Next
PostPosted: Thu Nov 06, 2014 4:32 pm
For those with steel bullbar on the front and stock suspension how do you find how the suspension holds up? I'm expecting a bit of drop in the front but don't want to compromise on comfort. To raise the front can I get away with just running bilstein shocks and 40mm plus springs up front? Should you match the upgrades at the rear?
Anyone track down front bilsteins from the U.S.?
PostPosted: Thu Nov 06, 2014 5:47 pm
I am thinking about the same thing. Just got my Dobinson deluxe bar :D and now looking for a winch.
When I did my NS Pajero up, ARB bar and 9000 winch, I just changed out the coils with Lovell springs. HD 2 inch lift all round which is the mid spec upgrade for Lovells. The next level up was mine spec so heavy loads all day work. Kept the shocks and struts on the Pajero as they are said to be made by Bilstenis. It improved the ride heaps, even with the standard shocks, less body roll firm but not harsh and lifted up the nose, noticeable lift but not over the top. I don’t bash along dirt tracks day in day out so not really interested in expensive suspension up grades.
I had a look at the stock shocks that are fitted to the D Max and they are made by KYB. KYB are one of the more reputable players in the shock business so I am thinking about just changing out the front coils with Lovells, to get the height back plus a bit and leave the rest as is. That will cost about $300 plus a wheel alignment. I am quite happy with the stock ride of the LS dual cab and don’t think a $2000 suspension upgrade will really be worth it for the driving I do. What ya thing D max tribe?
PostPosted: Thu Nov 06, 2014 6:09 pm
PostPosted: Thu Nov 06, 2014 6:14 pm
PostPosted: Thu Nov 06, 2014 6:31 pm
I fitted an ARB steel bar and noticed the drop and you could notice the difference in handling ie braking, cornering; it felt very nose heavy. Old Man Emu kit on and feels much better in every situation. Costly but worth it for what my opinion is worth.
PostPosted: Thu Nov 06, 2014 6:41 pm
PostPosted: Thu Nov 06, 2014 6:45 pm
Ok, thanks. Bugger I was hoping to hear more like "nah she'll be right mate. Stock suspension will be fine" :lol:
Dobomax I got the dobinson deluxe as well. You happy with it?
PostPosted: Thu Nov 06, 2014 7:04 pm
I'm still running the factory suspension on my 2013 LS-M. I have fitted a steel TJM bullbar, 9000lb winch with steel cable, and front brushbar/side steps.
I can't really say I've noticed a binary difference ie it's suddenly good or bad. Can notice it's slightly lower - as to be expected - but the handling and dynamics, well honestly can't really say it's better or worse.
I suppose this is because the accessories have been fitted separately over the past 18 months. Cumulative effect hasn't been noticed. I am sure that if I was to drive a brand new LS-M with nothing up front I'd notice a difference in driving dynamics.
If you checkout my recent pictures in the trips section - viewtopic.php?f=32&t=873 - you'll see how it all sits. But also, I've fitted slightly taller tyres which fill in the guards, so the pictures will be misleading when comparing to factory wheels too, in terms of how low the suspension is.
PostPosted: Thu Nov 06, 2014 7:21 pm
Similar to Danno.
Bullbar dropped 25mm and became a bit "wollowee" didn't put the winch in.
After 2" dobinsons all round, all much better.
2014 LS-U crew cab dobinsons bullbar & lift tjm rear step egr canopy
PostPosted: Thu Nov 06, 2014 7:38 pm
If your after a factory coil feel you can go to outback armour front struts and space the coil up to your preference you can make it sit 20 to 60 mm higher.
