[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4757: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4759: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4760: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4761: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
NEW D-MAX /MUX /COLORADO FORUM •
It is currently Wed Aug 12, 2020 9:30 am
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Mon Dec 15, 2014 11:25 am
Hey app master, just one comment on using spacers with progessive rate coils. Not sure if this is what you have installed. But with progressive rate coils, fitting a spacer only loads the coil up a bit, and in turn you lose some of the progressiveness, or with larger spacers, all of the progressiveness. Better to fit the right coil than use spacers IMHO.
PostPosted: Mon Dec 15, 2014 11:35 am
PostPosted: Mon Dec 15, 2014 12:06 pm
PostPosted: Thu Dec 18, 2014 6:59 am
Great info guys
:D
PostPosted: Thu Dec 18, 2014 12:44 pm
Does the use of spacers really "load up a coil"?
I would have thought all it does is reposition the coil further away from the fixed member/chassis mounting, thereby creating a lift, but no difference to suspension action apart from using up some of the droop value of lower arm.
PostPosted: Thu Dec 18, 2014 2:35 pm
My thoughts are you will be reducing the overall length of the coil by using spacers and as such would be putting a small but constant amount of compression on the spring. Therefore you must be putting some load on the coil by using spacers. Any load would reduce the first stage of a progressive coil. Yes or no?
PostPosted: Sat Dec 27, 2014 10:09 am
2014 LSU dual cab
PostPosted: Sat Dec 27, 2014 11:24 am
PostPosted: Sat Dec 27, 2014 1:03 pm
Spacers in or outside a strut is carrying the same weight of vehicle per corner as each other. What is the difference?
One the strut is spaced down with shock in normal position, other has the coil more pre stressed ie, harder riding but can't accept as much movement of stroke other wise the spring will become solid under full compression. That will make for interesting forces being applied to the strut tower and possible technical repairs.
The whole idea of a suspension is absorbtion and compliance, yet some folk want to reduce it. Strange phenomenon that.
PostPosted: Sat Dec 27, 2014 1:19 pm
Ah, I see what you are saying Tink... Yes, I was referring to the spacer between the top of the coil and the strut tower (like what I have in Booger Mobile)... I guess in one of those strut/coil combo situations, inserting a spacer in there would put the coil under load, as the strut would be maxed out when fully extended... Makes sense!!
2014 LSU dual cab
