It is currently Thu Jan 24, 2019 2:32 am
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Corbz sx dual cab
PostPosted: Fri Oct 09, 2015 3:44 pm
Silver05 wrote:
Where are you? If in NSW you are supposed to have an engineers certificate for the fitting of a long range tank to remain legal. I don't think anyone gets one and I'm not anyone gets knocked back for it but that is the way it is here in NSW.
I've had a long range fuel tank engineered before!
On my previous Hilux, I had several things to tick off that got engineered. Talking 15 years ago and a ye-olde LN106 2.8 litre diesel:
- Aftermarket turbo and intercooler
- Suspension lift
- Body lift
- Wider, taller wheels & wider track
- Sunroof
- Big exhaust system
- Replacement front seats (from a Honda Accord!)
and
- Long range fuel tank :lol:
Everything passed! :D
PostPosted: Sun Oct 11, 2015 9:08 pm
Coming along now got the uhf to do and some power outlets
PostPosted: Mon Oct 12, 2015 6:18 am
The tjm battery tray is a lot better built and designed then the piranha one, and I found a spot up under the guard out of the way for the circuit protection, I also get 600klm befor the fuel gauge even moves off full with the long range tank loving the little Isuzu so far I was worried coming from a landcruiser but happy I made the switch.
PostPosted: Mon Oct 12, 2015 6:54 am
If you get 600km before the gauge moves off full, then the setup of the gauge, ie having a gauge to indicate fuel usage, is completely out of whack in your tank.
Like the OE tank there is a while of use before the gauge moves down, but having 600km before anything indicates leaves you playing catch up with the rest.
Alternatively, with the available fuel on board and a little experience you can probably judge better than the system can.
Looks like no attempt to calibrate the gauge to the tank was made at any time during fitment.
PostPosted: Mon Oct 12, 2015 7:25 am
Your right but once the gauge starts to move its just like a normal tank when it says empty its empty I just get a lot further then a standard tank before it move off full not an issue really is it.
PostPosted: Mon Oct 12, 2015 7:35 am
Picked up the genuine mags cheap off gum tree they look a lot better then the standard steel rims, I've been offered a 2" RAw suspension kit on the cheap but don't know a lot about raw anyone els use it??
Also if any one chasing 4 genuine steel Mags with brand new tyres on them let me know.
PostPosted: Tue Oct 13, 2015 11:55 am
Mounted uhf today copied the location from a few threads I've read but mounted it differently By drilling holes on consol to line up with mounting holes in unit itself, I wrapped the unit in denso tape to prevent any movement come up well I thought. Also found u don't have to remove the entire centre consol the gear stick surround just unclips bringing everything u need to mount the uhf.
PostPosted: Tue Oct 13, 2015 2:37 pm
A look at the size of the windscreen washer bottle
PostPosted: Tue Oct 13, 2015 2:43 pm
Why'd you pull the guard off?
PostPosted: Tue Oct 13, 2015 4:47 pm
I mounted some circuit protection there for my auxiliary battery it just made it a lot easier to mount them with it off if u zoom in you can see them above washer bottle, simple to get to when it's all together.
