It is currently Sun Apr 21, 2019 12:41 pm
Post new topic Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
 Post subject: Britts SX buildup
PostPosted: Mon Oct 03, 2016 1:36 pm
Hi All,
Been lurking for a while and have finally started putting it together slowly,
Started with a white 5/16 SX, dual cab with a steel tray 1800x1800.
Sent from my SM-G920I using Tapatalk
 Post subject: Re: Britts SX buildup
PostPosted: Mon Oct 03, 2016 1:39 pm
The under tray toolboxes fitted up and the mudguards moved as the front ones were hitting the tyres offroad, and a better bracket for the fuel filler.
Note 460mm overhang past the rear of the chassis.
PostPosted: Mon Oct 03, 2016 1:42 pm
Installed the battery box for the dual battery's under the tray, its a Roadsafe brand from Opposite Lock, wiring to follow in a couple of weeks
PostPosted: Mon Oct 03, 2016 1:44 pm
Redarc remote head unit installed today into LH side blank,
PostPosted: Mon Oct 03, 2016 1:46 pm
While the panel was down rearranged the blanks on the RH side.
PostPosted: Tue Oct 04, 2016 9:40 am
Great stuff. I would have concerns of crushing the undertray tool boxes off road. I love the battery holder underslung. It looks very sturdy. Make sure the battery has no up and down or sideways movements when fitted. They are heavy and would act like a sledge hammer if not prevented from moving and could cause welds to crack or metal to fatigue. Love the redarc fittment.
I know what you mean about tray overhung past end of chassis too. I hope to get an SX but space cab with a 1950mm internat length alloy tray at this stage of planning. I know I will have tray overhand too. Not sure exactly how much though.
PostPosted: Tue Oct 04, 2016 10:12 am
Another pic of the battery box, I'm going to put another piece of unistrut in the middle for extra strength.
PostPosted: Thu Oct 13, 2016 7:20 am
Can you please show where you have mounted your redarc main box? We are trying to install and work out the best location and your set up looks great. :D
PostPosted: Thu Oct 13, 2016 5:40 pm
Main box is located behind centre console kick panel.
PostPosted: Sun Oct 16, 2016 1:44 pm
Fitted the Projecta fused terminal block, easy installation, cut original using tin snips leaving bolt hole file to fit and bolt up.
