It is currently Thu Jan 24, 2019 1:34 am
Post new topic Reply to topic  [ 75 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8
PostPosted: Thu May 17, 2018 7:14 am
Ryan
The pink wire in the loom which runs to the towbar solenoids is large enough to power a reverse light or light bar. If you join to that pink wire and have it as the main supply to the lightbar relay, it can then be switched in ON in a couple of ways.
Because only small current flow is needed for a realy coil, the reverse signal can be picked out of the loom inside the cabin, (along sill) and a 12v source found inside the cabin.
Have that reverse power fed to a single pole double throw centre OFF switch on one side of the three switch legs. The other side switch leg feed it with 12v. The centre leg runs to the relay coil at the rear and that will allow you to:
Aways have reverse lightbar come on when reversing if swithc in that position.
Always have it switched OFF when not required, ie around town. Centre position.
Always able to turn on the LED bar to use as a work light.
PostPosted: Fri May 18, 2018 8:21 am
Duck wrote:
Must be handy being able to replace the clutch yourself !! If I pulled mine apart that would be the end of the ute. have to settle for paying for labour.
I don't mind paying, but I do hate the helplessness of not being able to trust that a job will be done properly. Not being a mechanic, I can pick up some errors myself, but who knows how many I can't pick up?
PostPosted: Fri May 18, 2018 10:22 am
Sorry Duck I didn’t see your comment, yeah it is handy that’s for sure. I don’t know how people pay for it, I would be broke
PostPosted: Fri May 18, 2018 10:28 am
I’ve PM you Ryan,
PostPosted: Sat May 26, 2018 11:45 am
Recent Vic high country trip
