It is currently Tue Jan 21, 2020 9:36 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Ducks 13 Max build
PostPosted: Sat Jul 22, 2017 6:11 pm
Led lights in rollbar & under tonneau cover
PostPosted: Tue Nov 07, 2017 4:19 pm
Put the catchcan in straight forward install.
PostPosted: Tue Nov 07, 2017 4:33 pm
Had the OME comfort nitro suspension fitted. Came up 35ish mm quite a ride difference.
BFG KO2's 265/75/16.
All up just under 3" raise of vehicle which will help on the sand.
PostPosted: Tue Nov 07, 2017 4:37 pm
Side steps next
PostPosted: Mon Mar 05, 2018 9:18 am
ARB side steps on, makes a bit akward getting in & out hitting your leg on them. But gives protection & looks good.
fuel filter & seat covers next.
PostPosted: Sun May 06, 2018 2:02 pm
coming along nicely. have you found it easy to service the catch can in that position? still on my list to do.
cheers
PostPosted: Thu May 10, 2018 5:23 pm
cheers
I was undoing the can which was a bit of a pain, then another member here said he uses a syringe to drain it from the dipstick which is so much easier.
PostPosted: Fri May 11, 2018 8:32 pm
Yep takes to 2 mins with the 100ml syringe and plastic hose. Check ebay or aliexpress.
PostPosted: Tue May 15, 2018 1:56 pm
Mate they look good. I also want to put some bigger rubber on standard rims. any issues with rubbing?
PostPosted: Tue May 15, 2018 4:32 pm
Nothing at all, I don't know how they would go without higher suspension, but with the OME they work a treat. I heard that a ko3 is coming out ? Not that I will be getting new rubber for quite a while.
Users browsing this forum: Google [Bot] and 1 guest
