It is currently Sun Apr 21, 2019 12:31 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2, 3  Next
 Post subject: MY14 Space Cab LSU
PostPosted: Thu Jan 23, 2014 8:59 pm
Post a few pic of thins I've started
In the yard
With the wheels of the old car 265/65lt17 Dynamic Mambo 17x8 rim with +20 off set
James
 Post subject: Re: MY14 Space Cab LSU
PostPosted: Thu Jan 23, 2014 9:30 pm
got the pic resizing sorted i think
PostPosted: Thu Jan 23, 2014 10:11 pm
The UHF and older style HF Radio fitted in the sunglasses holder had the same setup in the Triton as well, just got to work out where to mount the Auto Tune Antenna yet
Have mounted the heat exchanger under the fan cowl on a bracket above the bash plate, with the pump for it behind the grill on the bonnet support brace, inlet and outlets are in the bumper grill area, post pic later
Canopy should be here this week if it can be found ? strange things happen to things on there way to WA form over east
James
PostPosted: Fri Jan 24, 2014 6:25 am
Hi Slug,
That's an interesting install you have there. I notice the rear view monitor is mounted above the mirror, how do you find that for operation/visibility? Any probs running cables down the A pillar? Where did you pick up the trigger for the camera, up the front or from the rear reversing light?
Regards
Scooby
PostPosted: Fri Jan 24, 2014 6:52 am
Slug
What is the heat exchanger and pump for? What are you exchanging heat from and how is a pump required?
PostPosted: Fri Jan 24, 2014 5:59 pm
Slug
That would be a hot water/shower thingy.
If you've got time could you post pics of that please Slug, and what type etc. and how well does it work? looking at that myself.
Cheers.
PostPosted: Sat Jan 25, 2014 7:22 am
I was hoping it was some high performance piece of kit but it is just a hot wash unit. Only dirty people wash anyway!
PostPosted: Sat Jan 25, 2014 4:44 pm
the heat exchanger the bash plate then covers it ( changing that to one that you can call a bash plate)
the pump motor cover to be fitted the green hose fittings are the inlet & outlets for the shower and the 7 pin conector is for the switch to turn the pump off & on
We do a lot of remote 4x4 and over the years some of the trips, Canning Stock Route, Simpson, nearly all of Len Beadell Tracks, victorian and NSW high country SA Tracks and outback QLD
got love the classics, turbo lockers front and rear, 300ltr fuel 100ltr water, extra low range reduction slow as any thing on the highway but great in the bush
PostPosted: Sun Feb 02, 2014 8:53 pm
Found these pictures of the old triton in a Holden dealers add in perth
Note the D Max wheels which were swapped pre pickup
Had to put WA rego on before you trade over here, they require if its an interstate reg prior other wise it has to go over the pits
PostPosted: Mon Feb 03, 2014 8:12 am
Hey slug how do ya rate the triton to the dmax the good bad etc
