It is currently Sat Feb 23, 2019 1:13 pm
PostPosted: Sat Apr 23, 2016 4:14 pm
Can anyone share where the location of the headlights warning buzzer is on a 2013 dmax? Previos owner must have disconnected it and I have a habbit of leaving them on..
Also,If I reinstate this buzzer, will that also re-activate the door open buzzer? as I dont have that at the moment either.. not that I want it! :roll:
Cheers!
PostPosted: Sat Apr 23, 2016 5:05 pm
Don't know where it is but it is the same buzzer for keys and doors, once reconnected it's easy to then fix the keys one by itself.
Good luck finding it though if you can't set it off in the first place!
PostPosted: Sat Apr 23, 2016 6:00 pm
hm. If I cant find the module then I will install an after market warning alarm of some sorts i guess
PostPosted: Sat Apr 23, 2016 6:20 pm
Think it has it's own fuse. Is it's fuse missing from the fuse box under the right side of the steering wheel?
PostPosted: Tue Apr 26, 2016 11:24 am
Tink, Unless I'm blind, the only fuses missing are the ones left blank on the diagram located on the back of the fuse panel door..
Not to worry.. I have just installed a $4 buzzer between the supply side of the Number 3 Audio fuse and the Brown switched 12V+ of the dash board illumination adjuster.
The buzzer sounds when the ignition is 'off' and the light switch is 'on'.
So if your in need of a quick cheap fix, buy on of these from Jaycar : $3.95
http://i140.photobucket.com/albums/r6/k ... vgcb1l.jpg
And wire it in like this..
http://i140.photobucket.com/albums/r6/k ... lxk0aw.jpg
Thanks Mark.
PostPosted: Mon Feb 04, 2019 5:57 pm
I'm trying to find that 'how to' thread now funny enough, I've owned my truck for a few years now, should have disabled that feature long ago, is it just cutting/removing one wire that comes from the back of the ignition switch??
PostPosted: Tue Feb 05, 2019 7:05 am
Right here 6th post down viewtopic.php?f=13&t=346&hilit=keys+buzzer
