It is currently Sat Feb 23, 2019 12:27 pm
 Post subject: Reverse camera wiring
PostPosted: Tue Jan 29, 2019 10:47 am
Hey Guys, new to this forum so apologies if this has been brought up before.
I want to run an aftermarket reverse camera in my 2014 Dmax x-runner and wondered if anyone has any tips on where and how to run the wiring into the cab from the camera.
Thanks in advance.
PostPosted: Tue Jan 29, 2019 11:02 am
CN80
I have a 2011 Dmax and presume the floor ports are the same. Each one, under the carpet/vinyl, is a circular disc which has two lugs below the floor and the disc above. Sealed in though.
The profile is stepped on mine and the middle edge rearward facing. I drilled through the disc from back to front and with two holes I ran UHF and camera cabling. All is sealed with a good quality sealant/Silicon. Doing that allows for the cables to be zip tied to the underside of the cab as the cables go to the rear.
Worked ok for me. It also meant no additional holes in cab skin.
If drilling, make sure yuou don't get any drill contact with body deadener layer or carpet, it will wind it uo very quickly and damage anything it touches.
PostPosted: Tue Jan 29, 2019 11:26 am
Thanks mydmax
PostPosted: Sat Feb 16, 2019 9:24 am
I drilled and went through the sill. It was easy
