It is currently Sun Apr 21, 2019 11:02 am
PostPosted: Fri Feb 16, 2018 1:22 pm
I own a 2015 Isuzu Dmax about 34k on the odometer. Recently had issues with a light flicker ( water seperation light ) and a hissing sound at high revs 3500-4000rpm.
Thought it was the fuel filter being clogged and restricting flow. Discovered intake hose had a split causing bad seal creating problem.
PostPosted: Fri Feb 16, 2018 5:27 pm
A water separation light is different to a filter restriction light isn’t it? The two functions are quite different and mean different conditions exist.
Which hose was split? Normally turbo pressure is detected as a leak noise if a turbo pressure side hose is split and pressured air is being forced out.
PostPosted: Fri Feb 16, 2018 8:25 pm
The noise at 4000 rpm is an easy fix......don't rev it that high there's absolutely no need and strangely enough all it does up there is....well..make noise.
