It is currently Thu Jan 24, 2019 2:14 am
PostPosted: Fri Feb 16, 2018 1:22 pm
I own a 2015 Isuzu Dmax about 34k on the odometer. Recently had issues with a light flicker ( water seperation light ) and a hissing sound at high revs 3500-4000rpm.
Thought it was the fuel filter being clogged and restricting flow. Discovered intake hose had a split causing bad seal creating problem.
PostPosted: Fri Feb 16, 2018 5:27 pm
A water separation light is different to a filter restriction light isn’t it? The two functions are quite different and mean different conditions exist.
Which hose was split? Normally turbo pressure is detected as a leak noise if a turbo pressure side hose is split and pressured air is being forced out.
PostPosted: Fri Feb 16, 2018 8:25 pm
The noise at 4000 rpm is an easy fix......don't rev it that high there's absolutely no need and strangely enough all it does up there is....well..make noise.
Users browsing this forum: No registered users and 12 guests
