It is currently Sat Apr 20, 2019 12:28 am
PostPosted: Tue Jun 26, 2018 4:20 pm
In heavy rain that we've had more recently in Sydney, I've had water puddling on the floor of my 2015 LSU near the left hand side coming from the bottom of the dash probably the air vent
, its not excessive, but enough to be a concern, seems to happen when its parked on the driveway
anybody had this happen, I'm thinking it might be a common problem with other utes
cheers
Hodgo
PostPosted: Tue Jun 26, 2018 5:26 pm
Hodgson
The plenum chamber which has air flow through it, ie, gap in front of the windscreen must drain water at each side. Perhaps a leaf and dust build up has blocked the side drains and the water builds up and enters the air inlet.
The aircon drain must also be clear. It exits on LHS of the firewall, down low. It can often be blocked by wasps and crud, the air system then overflows into the vehicle instead of draining.
Users browsing this forum: No registered users and 7 guests
