It is currently Sat Apr 20, 2019 12:18 am
PostPosted: Thu Jul 12, 2018 1:42 pm
Some interesting changes for all you lot down there https://www.mr4x4.com.au/wp-content/upl ... i_vsi6.pdf particularly relating to tyre and rims..
PostPosted: Fri Jul 13, 2018 3:51 pm
As noted below 75mm lift is perfectly legal in NSW and I believe Victoria, pretty sensible really as most people are happy with this. There are still issues trying to re calibrate your speedo but re engineering the stability control problem is sidestepped.
Regards Charles
"In addition to the above, the following are not considered to be significant modifications and do NOT require assessing or certification:
a. Except where specified below, modifications to the suspension that does not increase or decrease the vehicle’s ride height by more than 50mm.
b. Changes in the diameter of the wheel and tyre combination of up to +/- 7% of the largest size specified by the vehicle manufacturer.
c. Modifications to the ride height up to 75mm that incorporate a maximum change in the suspension of 50mm, and/or an increase in the diameter of the wheel and tyre combination of up to 50mm.
d. Restoring a vehicle to the original trim height as established by its manufacturer to compensate –
i. for sag due to normal wear-and-tear"
Users browsing this forum: No registered users and 6 guests
