It is currently Thu Jan 24, 2019 1:43 am
 Post subject: Auto Box
PostPosted: Thu Jun 14, 2018 3:15 am
does anyone know how to reset a auto box on a isuzu as mine doesn't downshift when the brake is applied
 Post subject: Re: Auto Box
PostPosted: Thu Jun 14, 2018 5:42 am
Has it downshifted under brakes in the past?
If so, the switch alongside the the stoplight switch is possibly the fault. It is activated when the brake is pressed to signal to the ECU the brake has been pressed. Maybe it doesn't make contact as it should.
There are two sections to that switch, two wires which operate the stop lights and the other section is the 2 wires to make the ECU signal.
I would check that first.
