It is currently Wed Feb 19, 2020 12:30 pm
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: Mon Aug 31, 2015 7:42 pm
Sent from my iPhone using Tapatalk
PostPosted: Mon Aug 31, 2015 7:43 pm
I believe the Besco transaxle is GL-3, I'm using a synthetic GL-4.
At any rate they differentiate between the MSG transmission being able to take an engine oil and the MUX which doesn't.
Anyway I hope mine fails during the warranty period if it's going to die
PostPosted: Mon Sep 09, 2019 7:26 am
Well just got back from 10 days on Fraser Island & while there had some serious squealing coming from the thing under the bonnet of all the time but 1st & 2nd gear as per this post ! It has done it once or twice since being home. Belts all look good and tight, my question is if it is a gear box issue does it do it all the time or occasionally. Hopefully just a wet belt.
PostPosted: Mon Sep 09, 2019 6:24 pm
A squeal may be the belts. Tightness isn't the governing factor though. IF,
your aircon, water pump, pulley idler and crank pulley are on a V belt and the crank, alt and water pump is run by a 7 PK BELT, after a while the V wears and becomes lower in the groove and therefore less rotation than the 7PL is forcing the fan V faces to be faster than the rate of the V belt transport from the crank pulley. That causes squeal at the V in the water pump V groove. New belt fixes it. Alternatively a shorter belt which only runs from water pump groove to idler and aircon also removes the out of synch of the two different belt drive systems.
PostPosted: Mon Sep 09, 2019 8:24 pm
The gearbox issue doesn't really sound like a wet or loose fan belt, no way could it be mistaken for that, it's more of a buzzing screechy noise and most noticeable at around 2000 rpm and sometimes even at idle. If you search the forum you will find more info but don't overly concern yourself with it if it is the dreaded 5th gear synchro noise as it's harmless and in some cases (like mine) the new parts won't fix it anyway.
PostPosted: Tue Sep 10, 2019 2:45 pm
Thanks mydmax & Dan, definitely not all the time so sounds like a squealing belt. Obviously I am no mechanic I stick to pin striping restoration!!
Thinking about it could have even been squealing from one of the boys in the back seat because of the tough fishing conditions.
