It is currently Sat Jul 04, 2020 7:37 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Steering Stops
PostPosted: Wed Jun 01, 2016 1:19 pm
As pointed out before Isuzu do not have the market cornered on broken cv's, all the Ute's do it, Ford is actually worse, the only one I haven't heard much about is the Dak Dak.
Have to disagree Danno, at least around here , got mates with every other 4x4 , never experienced breakages as easy as these things , the more I look into it the more I'm finding .
If you were to look at percentages of the blokes I know personally and the others I meet in the Highcountry
This model Isuzu is a very low % , but the amount of broken CV's is the most I have ever heard of
It's 100% more than I have broken myself .
I invite anyone to come and do a trip with us and see for yourselves out country and tracks are the best in Oz .
PostPosted: Thu Jun 02, 2016 6:41 am
gmax Mate , check out this thread I started , couple of photos of a great old Landy , that came to my rescue
viewtopic.php?f=5&t=1901
PostPosted: Thu Jun 09, 2016 7:43 pm
This is my left CV when on full left lock , its jacked up , wheel would be at full droop and turned so the back steering stop is in contact , normal driving and turning the rear stops do not make contact , the right front limits the left lock , left front limits right lock ,
But the rear stop is only a bee's dick from touching , so lets say the right wheel is on a bit of a bump , left wheel drops into hole , forces that wheel back just a bit , crunch there goes another CV
What do you blokes think of that CV angle .
PostPosted: Thu Jun 09, 2016 7:52 pm
I don't even Wanna look lol
PostPosted: Thu Jun 09, 2016 7:53 pm
At the cv jacko not your new thread I'll go look now at that
PostPosted: Thu Jun 09, 2016 8:39 pm
With both wheels on the ground it wont look that bad , that's the extreme , but I think it will break before it gets to that angle anyway .
If you start the car and turn to full lock it will , spring back a bit , you really need someone to hold it on full lock with the motor running .
PostPosted: Thu Jun 09, 2016 9:05 pm
Makes you cringe doesn't it.
PostPosted: Thu Jun 09, 2016 9:14 pm
Yep and it makes a very loud sorta crunch , it just has to break .
PostPosted: Fri Sep 28, 2018 2:55 pm
So What's the verdict on you bolt on stops ? Have you given them a good test yet ? How far out from the original stops do they have to protrude without not having a B double turning circle. This is one of the worst front suspension setups that wrecks a great vehicle.
Keep up the good work.
Joe
PostPosted: Fri Sep 28, 2018 11:00 pm
It was about 6mm , I think , it didn't make much difference to the turning radius .
I didn't break anymore CV's after the second one and fitting the stop but I was really careful turning when in 4WD , I did a lot of 3point turns where I didn't have to .
Because of the risk of the inner guards cracking and having to worry about the CV's , I no longer own a Isuzu .
