It is currently Wed Jan 23, 2019 5:02 pm
Post new topic Reply to topic  [ 87 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9  Next
PostPosted: Sat Nov 26, 2016 8:09 am
if you want to get your atf reading on an ultra gauge you need to modify a mgauge to:
tData: 07E2221940
TCtrl: 93
RCtrl: 31
RPos: 2008
Mtch: 621940
X: 0001/ 0001 +FFD8
Out Format: 0
Ave: 0
Left/Right: 31
PostPosted: Mon Nov 28, 2016 11:44 am
tData: 07E2221940
TCtrl: 93
RCtrl: 31
RPos: 2008
Mtch: 621940
X: 0001/ 0001 +FFD8
Out Format: 0
Ave: 0
Left/Right: 31
That matches the programming in mine so should be sweet!
2014 LSU + ECB nudge bar, Rhino roof rack, Rhino-rack awning, SMM steel canopy, Outback drawer & custom fridge slide, B&M ATF cooler, UltraGauge, aux battery & dc-dc charger, Dobinson & Bilstein suspension, AVM hubs.
PostPosted: Fri Apr 21, 2017 12:27 am
Hi everyone, I've read of being able to reset from limp mode using some of these scan tools. Do the Scangauge/Ultragauge support this?
PostPosted: Fri Apr 21, 2017 6:39 am
Yep.
PostPosted: Fri Apr 21, 2017 10:48 am
Yes the UltraGauge in mine that I was advised to buy has been used a number of times for limp mode codes. Recently on the road I had to swap out a dead car battery and when I disconnected the old battery and reconnected the new, the egine warning lights come on and traction control lights etc and the Dmax went into limp mode, which was accompanied by a rough idle. I cleared the code using the Ultragauge easy enough. But last weekend when disconnecting the battery terminals so I could pull my broken winch out of the bullbar, when I reconnected everything again it again went into limp mode. Whilst again I could clear the codes, is there any reason it is doing this. It doesn't happen any other time.
PostPosted: Mon May 29, 2017 9:00 pm
I am trying to get my UltraGauge to show my auto transmissions temperature on my 2015 D-Max. I googled and found the codes and entered them but it does not work. I must have misunderstood something. Attached is a photo of what I have entered, can anyone tell me where I have gone wrong, or even better if you have a photo of an UltraGauge that actually works.
Chris
PostPosted: Tue May 30, 2017 8:40 am
Hi Chris,
Your problem is with the RPOS value. It should be 2008 for the Ultragauge. 3008 is used for the Scangauge, so it looks as if you have a bastardised version.
Geoff
PostPosted: Wed May 31, 2017 10:38 am
If you change the Left/Right value to 30 the displayed value will be in whole numbers only.
PostPosted: Wed May 31, 2017 7:40 pm
Ah yes, that's what I have. Did you get it working?
 Post subject: SCANGAUGE CODES
PostPosted: Tue May 29, 2018 9:58 am
Hi, we have a 2016 dual cab D Max four wheeler and are towing a 2.7 t gross caravan from Tassie up to Darwin via the Big Red Bash.I've just bought a Scangauge II and looked through pages in this forum for the ATF temp codes to put into it, I found that one and it gives me a read out, thanks tink for that one.
Can anybody tell me the codes for the,
1 engine coolant.
2 if it will read the EGT
3 volts
4 I found how to get it to show boost instead of MAP. But it is on a different screen to where the ATF temp is showing. I'm hoping to be able to get, the ATF, the coolant temp, boost and EGT showing all on one screen instead of having to scroll through pages whole driving. Any hints????
Cheers Kanga
