It is currently Wed Feb 26, 2020 8:32 pm
Forum rules
Please click here to view the forum rules
 Post subject: Ac controls
PostPosted: Sun Jun 04, 2017 1:29 pm
Hi guys has anyone had problems with the fan direction dial after removing the ac control panel? After putting it back together it sounds like it's not located correctly. And help would be awesome
 Post subject: Re: Ac controls
PostPosted: Sun Jun 04, 2017 3:22 pm
I could fix that in about 30sec but explaining it on a forum is near impossible, I tried here viewtopic.php?t=1012&p=9748 about 8 posts down and that's the best I can do, it's a REALLY stupid design and if you take it to Isuzu I guarantee they won't be able to fix it either. Good luck.
Stick your location in your profile for us please mate.
PostPosted: Sun Jun 04, 2017 4:14 pm
PostPosted: Tue Jun 06, 2017 12:51 pm
Oh man, I had this issues just recently when I changed my head unit out.
Could not for the life of me get those knob control cable plugged back in!
TAKE IT OUT
The easiest way to resolve was to pull the whole hvac unit/panel totally out (tip; unclip the fresh air level behind glovebox) and then work with it on the benchtop.
WHAT TO FIX
The little cog arrangement on the inside/back for the main two knobs (air direction and temp), comes out alignment inside the unit and need to be "re-seated".
The whole panel all screws and clips apart quite easily, and then goes back together just as easy.
Remember to check and re-align the main knobs on reassembly, so that they rotate all way around as meant too.
Still a PITA!
2013 LSU crew,auto,4x4,white,towb,tint,tubliner+Outback Armour lift,Ironman Bullbar,Alpha Canopy,PhatBars,Snorkel,Superwinch hubs,WhispbarHD racks,Provent 200, ecuwest tune,UHF,7"HIDs, Wheels 17x8 PDW w/Toyo OPAT2 275-65r17
PostPosted: Tue Jan 29, 2019 1:01 pm
I had the same problem when I was playing with mine.had to pull apart again and line up the weird shape cogs.managed to get it in the end.
