It is currently Mon Oct 14, 2019 8:38 am
PostPosted: Wed Jun 26, 2019 8:21 am
Been looking at servicing my dmax 5 speed auto myself, because of cost and to have it done properly without the BS. The following is my opinion only and im happy to be corrected.
isuzu's auto boxs are made by Aisin, toyota owns 49% of Aisin. the 5 speed box used in the previous dmax and hilux, fj cruiser etc are one and the same. the 6 speed box used on the current dmax and hilux are also the same. seems toyota rename the aisin boxs.
the previous 5 speed aisin used in the 12-17 dmax is the TB50-LS toyota call it the a750e 2wd and a750f 4wd.
the current 6 speed aisin used in the new dmax is the AWR6B45, but toyota call it the ac60.
it could be possible to find parts (filter,gasket) for the dmax gearboxs by searching with the toyota name for the gearbox and for me it works out cheaper.
link to tb50-ls/a750f pan fluid, filter change only
https://www.youtube.com/watch?v=LQjbD8LeYt4
link to tb50-ls/a750e diy full fluid flush
https://www.tacomaworld.com/threads/diy ... ion.68462/
link to aisin product page , interesting to see max torque input v chipped/remapped engine outputs.
https://www.aisin-aw.co.jp/en/products/ ... up/at.html
PostPosted: Wed Jun 26, 2019 11:37 am
4jj1
If only considering a fan fluid and filter change, it isn't going to achieve much at all. Same as if it had done 300,000km. You can only clean the pan of contaminant film on it's surface and any metallic particles will be on the magnets. Any crap caught on the filter will still be there if the pan doesn't come off. If they haven't gone through the filter then there they will stay.
If doing fluid and pan off, then yes, clean filter and a complete flush of the system is the only way if you are serious about your auto's internals. Clean fluid IS the key to longlife.
A pan change only is a small dilution of the total dirty fluid volume.
To change the fluid, a decent change of fluid, you will need 12 or more litres to see continuous clean fluid exiting from the return line fitting of the radiator heat exchanger.
I used 15 litres to change a mates Falcon after it went underwater. Pan off in that case of course. Run until it blurts out the exit and refill, a few times while changing through gears fast enough to make it select ratios, and reverse, to attempt/ensure some clearance of old fluid out of servo chambers. Not sure f anyone does that. Have to have rear wheels OFF the deck and on stands to do the job.
If you keep a volume track/account of what exits, you know what volume to add at each refill while doing the job so you don't run low too quickly.
Dirty or wrong fluid is something auto's don't like.
I used to rebuild them for a motor trader/motor wrecker. Often a complete dismantle of all clutch packs and servo chambers, (because a few businesses got suckered into using a fly bynight, oil trader for their fluid) hundreds of parts, older Honda 2 part Auto's are a challenge, valve body was in two separate sections.
PostPosted: Thu Jun 27, 2019 10:19 am
yes youre right mydmax, i was planning on doing a full flush. ill change the filter as well as its enclosed and difficult to inspect/clean it internally on the tb50-ls (look at the first link i posted). i need to flush it because the last time it was done it got genuine isuzu atf, which is semi synthetic, i want to change for full synthetic this time. apparently you need to get the tranny up to specific temp range for a proper fluid level check. i dont have a scanguage 2, so i might have to upgrade my obd scan tool as well.
My other option would be to supply and mark a new filter, take it to a tranny service place and request it to be flushed with full syn atf. id tell them ill be checking the fluid colour and filter after its done. I think they use a machine that drains , measures and replaces the atf. but like i said before its too much BS, its probably easier just to do it myself. ive paid top dollar before and been burned.
interesting that if you search for the auto gearboxes using the toyota name for them you can find upgraded valve bodies, and after market "compushift" transmission contollers. as well as filters and pan gaskets.
PostPosted: Thu Jun 27, 2019 1:33 pm
4jj1
If they actually flush the whole system, ie, most is held in the torque converter, a displacement unit is used. This has two chambers connected at the top but sealed from outside. As fluid plumbed to the empty chamber enters, it creates a pressure in the other side and the air pressure in one side forces the fluid out of the other side and into the box. Can be made from large poly pipe with screw caps. Fill the replenish side with new fluid of desired type and run engine. I would still operate the box through a much/many gear changes while it is happening though. Doesn't take long to dump it from one side to the other, just have to have a clear plastic exit line with LED torch to see the colour change and see fresh fluid not exiting the rad.
PostPosted: Thu Jun 27, 2019 3:38 pm
4jj1
Your research is correct and sounds like you know what you are doing.
To do a full flush on my Prado 150
( I) First marked a 20 litre container in litre increments, Then how many pump of my new oil to the litre.
(2) Disconnect out to container.
(3) Connect pump to return.
(4) Hand brake on. Motor on idle.
(5) Assistant Runs through all gears to clean out full system. (Make sure you keep up supply as old oil is replaced )
(6) When oil is running clean Shut down.
(7) When cool enough or over night . Drop sump and replace filter and replace oil dropped It should be clean.
(8) Do the normal oil level test to check.
PostPosted: Thu Aug 01, 2019 11:16 am
I had a look under my friends auto diesel prado, and the fluid pan on his auto box is identical to the one under my dmax. i guess these are the same gearbox too ( both 5 speeds made by aisin). the bell housing looked different. not sure if the extension housing is different, isuzu make their own transfer cases. So i guess the upgrades available for the toyota boxes will fit the dmax's as well. ive heard of a taller 5th gear, upgraded valve bodies for towing, programmable shift point controllers, and torque converter lock up controllers. as well as filters and gaskets.
PostPosted: Thu Aug 01, 2019 12:39 pm
Yes, Toyota and Isuzu both use Aisin boxes, a well recognized fact.
Not sure what a valve body mod change will do seeing the auto is controlled by solenoid valves to operate the timing, delay and speed of change etc.
The bell housing will be different because it isn't a Toyota engine in the Isuzu, and the extension/transfers case is different because they use different suppliers/makers.
Haven't heard of 5th gear ratio change, but if it exists the major parts of the planetary systems would have to be changed as the final ratios of the box is interdependent on each set of planetary units with 5th being an overdrive of the input shaft from the tc.
I would always be very wary about using a tc lock up device as the clutch in the TC is made to only handle a certain degree of torque loading. The box is programmed to change out of lockup if that happens. Making it continue to take higher torque than designed will ensure earlier replacement of the torque converter when the clutch packs it in.
If fluid is replaced at reasonable intervals you probably would not need a pan gasket or filter for a long time. Many "well serviced" autos have never had the pan off. Of all the autos I have rebuilt the pan rarely appeared to have EVER been off. What killed them is dirty fluid and/or wrong fluid. Most service people DO NOT replace ALL the fluid.
I replaced clutches in a Mitsubishi front wheel drive auto after it had been serviced and refilled with the wrong oil by the Mitsubishi dealer.
