Key In Ignition Beeper (FIXED !!)
charliej
Re: Ok so how did this happen
Post by charliej »
Same thing happened to me so I got a basic key cut and hid it on the out side of the D-max it will let you in but not start the car. What my problem was as I opened the door from the inside I would bump the lock shut and when the door closed it would remain locked. First time it was 5.30 am and I had to get the trouble and strife out of bed grab the spare key and drive 11 klms to where I worked (not happy) but the car was still running and diesel was approx $1.60/ltr at the time
Post by Danno »
Keep the topics together please fellas, there's already one running on this topic about disconnecting beepers and random door locking.
Isuzu'd
Re: Key In Ignition Beeper (FIXED !!)
Post by Isuzu'd »
Took the car in for it's 3k check up today...asked about the key beeper and whether or not there was a "button sequence" or some such to turn it off.
Short answer - NO. :(
Dynomike
Post by Dynomike »
Hi Folks!
As i'm also really annoyed by this beeping, i've tried to follow Simon's instruction.
I disconnected the plug, but i can't find any plug with only two wires.
Perhaps the german version is different?
Here a picture:
What now?
Greets, Joerg
ATFS SpaceCab Custom A/T, Cosmic Black, 200 HP - 530 Nm ...
Get the whole story.
Post by Danno »
That's it mate, just pull that plug apart, ignore the two wires thing.
Dropbear74
Post by Dropbear74 »
Dynomike wrote:Hi Folks!
Here a picture:
What now?
Best mod I have done. Silence.
Dynomike
Post by Dynomike »
Thank you for the fast reply DB.
Not to get you wrong, because my english maybe a bit rusted.
I just pull out the plug and that's it.
And this will only have an effect on the beeping?
Greets, Joerg
Post by Tink »
Correct
LST
Post by LST »
In our models it also makes the interior dome light stay on a bit longer
Isuzu'd
Post by Isuzu'd »
Wasn't there something about the headlight warning bell also attached to this?
