Rear axle cracked
Re: Rear axle cracked
Mal
I havesent a private message in this site. If you wish you can follow that and contact me. Further can be done.
There will be some differences to the new model diff centre area as they have a Locking diff, so some changes there. Haven't checked, but at a guess the housing casting will be longer and Crownwheel a bit larger which means the pinion (if similar length) has to be positioned slightly forward, hence the mounting face plate on the banjo.
