Remove Fuel Pressure Limiter Valve (4JJ1)
skelly
Post by skelly »
G'day all - quick query re the 4JJ1 engine in a 2007 Rodeo - I need to pull the fuel pressure limiter valve off but it's been fixed on very tight. Couldn't get it to budge even with a breaker bar. Anyone with experience that would advise for/against using a rattle gun to remove this valve? Common rail is still attached to the engine so I'm a bit nervous about applying force that could potentially damage the common rail itself. Any advice much appreciated.
DarrinS
Re: Remove Fuel Pressure Limiter Valve (4JJ1)
Post by DarrinS »
How did you end up loosening the pressure limiting valve?
What sealant do you use on the thread? I have a leak and need to reseal mine.
DarrinS
Post by DarrinS »
