Rear disc brakes for Isuzu
Danno
Post by Danno »
Finally something maybe useful from Pedders for all those who hate rear drums on their car http://d22enj1fxubdc2.cloudfront.net/si ... -final.pdf no word on price though but being Pedders be prepared to give up your first born or at least an arm or two.
http://www.newd-max.net/viewtopic.php?f=13&t=1684
Build thread http://www.newd-max.net/viewtopic.php?f=16&t=549
Re: Rear disc brakes for Isuzu
Danny
It would suit auto owners who are prepared to have discs and lose the left leg as payment. Arms needed for steering, so must be retained.
garrytre
Post by garrytre »
As far as I can see, just about any brake can be applied hard enough to skid, even on good bitumen. So 'better' brakes will not change that, except that they might skid a bit quicker.
Then that is modified by ABS, so as to not skid.
But as far as I can see, unless their kit comes with a better ABS sensor, (no sign of that on the .pdf) their claim of stopping 12 metres sooner from 100kmh can't be true.
"Independent Australian engineering test results proved that at 100kmh the TrakRyder rear disc braking system
upgrade stopped an average 12.3 meters sooner than original equipment."
I'm a theoretician, you two are practical and experienced. Where am I wrong?
garrytre
I am inclined to think the same, if under full braking, the ABS pump is applying it's full pressure to the brakes with the rotation sensor modified braking to each wheel and it simply stops lockup. Therefore the rear disc and drum should be both at the same, almost lockup point, so no variation in braking would be seen, or measured.
Only if and when the shoes have heated to lose friction ability with the drum is a deterioration able to be measured.
Most people don't drive along doing crash stops every 1/2 a kilometre to heat brakes past their once of emergency braking ability.
That poses the question how, independent is the engineering certifier. As you mentioned, no additional info was supplied, just a statement to pacify the ones wishing to buy the system.
There is no harm in having it, but as Danno said, being disabled after purchase may not be desired by most.
garrytre
Post by garrytre »
Yes, on the big hill coming into Adelaide from Melbourne, every now & then a truck cooks its brakes and doesn't stop, but I never heard of any cars doing it.
Still, I've got a bag of fruit - bull bar, winch, snorkle, difflock, breathers, - never use any of them, might as well get rear disks and a gold plated mermaid as well.
blokaflats
Post by blokaflats »
And what did they do with the handbrake...Not mentioned
towtug
Post by towtug »
blokaflats wrote:And what did they do with the handbrake...Not mentioned
Built into the disk brake assembly. More shoes and pads to replace. I was amazed at how thin the rear brake shoes are in the Dmax.
Mike
Post by Mike »
Hi fellows.
iam new to this , so i hope you can help me out.
I have a D-max 2015 model and i want to change the rear brakes to dis pads.
Can the Mux rear brakes fit onto the D-max.
i know they make a after market set, but for $ 2,000 it is a bit rich.
cheers Mike
Mike
Post by Mike »
fellows
can the MUX rear dis brakes fit onto the D-max rear
