2014 Dmax ECUWEST Remap Dyno results v leading chip
Forum Supporter - Anything relating to Ecuwest Performance Technology
ECUWEST
Post by ECUWEST »
Check it out here guys, we also can do M-ux.
http://ecuwest.com.au/isuzu-d-max-ecu-remapping/
Re: 2014 Dmax ECUWEST Remap Dyno results v leading chip
Post by Danno »
Have you got one of the torque curve?
sucksqueezebangblow
Post by sucksqueezebangblow »
any graphs with boost? or EGT?
interesting to see the factory tune keeps making power right up to 3500rpm, whereas the chip and ECU tune both drop off earlier.
I can't say I'm not a fan of more power.
freezy11
Post by freezy11 »
How many times do you take the car post 3000rpm :?:
But yes torque graph would be interesting as well.
Post by Danno »
freezy11 wrote:How many times do you take the car post 3000rpm :?:
Me? never, all it does is make more noise.
sucksqueezebangblow
yeah I don't either. I'd say the turbo is reaching its limit of efficiency with the extra boost
Turkey
Post by Turkey »
When do you take it past idle Dan? she still got 5k on her I take it ;-)
Post by Danno »
I back it in and out of the shed every now and then Turkey...but not often..
bravoboy300
Post by bravoboy300 »
So ive been doing a bit of research into remapping, looked at ECU west and Diesel power unlimited so far. My main concern is the idea of a "road tune". I understand that one car is tuned on a dyno, then that tune is flashed into multiple cars, but no 2 cars will be exactly the same. Shouldn't each and every car be run on the dyno during the tune?
also do you have a dealer in NSW?
Hunter
Post by Hunter »
For a newbee....What is the difference between re-tuning and re-mapping or are they one and the same.
Since fitting the EGR plate the light came on a couple of times but comes on and stays on even after being cleared so I was thinking of having something done to remove it altogether..
Hunter
